Introdução
In this guide you will learn how to remove the back cover in order to access and replace a damaged or broken hard drive.
O que você precisa
Begin with the laptop lying to its back revealing its underside.
Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
Unscrew the 4mm screw, and slide the cover off away from the computer to reveal the housing for the hard drive and RAM boards.
3 outras pessoas executaram este guia.
