Ir para o conteúdo principal
Samsung NP270E5E-K03US Hard Drive Replacement
O que você precisa
  1. Samsung NP270E5E-K03US Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Samsung NP270E5E-K03US Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Begin with the laptop lying to its back revealing its underside.
    • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
  2. Samsung NP270E5E-K03US Hard Drive Replacement: passo 2, imagem 1 %32 Samsung NP270E5E-K03US Hard Drive Replacement: passo 2, imagem 2 %32
    • Completely remove the battery from the laptop.
  3. Samsung NP270E5E-K03US Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Samsung NP270E5E-K03US Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32 Samsung NP270E5E-K03US Hard Drive Replacement, Hard Drive: passo 3, imagem 3 %32
    • Unscrew the 4mm screw, and slide the cover off away from the computer to reveal the housing for the hard drive and RAM boards.
  4. Samsung NP270E5E-K03US Hard Drive Replacement: passo 4, imagem 1 %32 Samsung NP270E5E-K03US Hard Drive Replacement: passo 4, imagem 2 %32
    • Locate the gray hard drive cover, and remove the four corner 3.5mm screws.
  5. Samsung NP270E5E-K03US Hard Drive Replacement: passo 5, imagem 1 %32 Samsung NP270E5E-K03US Hard Drive Replacement: passo 5, imagem 2 %32
    • Lift the hard drive cover by pulling upwards on the removal handle.
    • You can now remove the hard drive from the laptops housing freeing up space to replace your damaged or broken hard drive with a new hard drive.
Conclusão
3 outras pessoas executaram este guia.
Kyle Golden
Membro desde: 03/23/17
353 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 20
Duração total: 1,700
