Ir para o conteúdo principal
Samsung NP-R540-JA09US Hard Drive Replacement
O que você precisa
  1. Samsung NP-R540-JA09US Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Samsung NP-R540-JA09US Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Flip the device to the bottoms-up position and locate the panel that says HDD.
    • In case of damage to panel, the HDD panel is just immediately right of the optical drive, and opposite from the battery
  2. Samsung NP-R540-JA09US Hard Drive Replacement: passo 2, imagem 1 %32 Samsung NP-R540-JA09US Hard Drive Replacement: passo 2, imagem 2 %32 Samsung NP-R540-JA09US Hard Drive Replacement: passo 2, imagem 3 %32
    • Remove the two 3.7mm securing screws with a Phillips #0 screwdriver.
    • After removing the screws, remove the panel covering the HDD.
  3. Samsung NP-R540-JA09US Hard Drive Replacement: passo 3, imagem 1 %32 Samsung NP-R540-JA09US Hard Drive Replacement: passo 3, imagem 2 %32 Samsung NP-R540-JA09US Hard Drive Replacement: passo 3, imagem 3 %32
    • Remove the screws on the bracket and then remove the bracket by pulling up.
    • Once the bracket has been removed, slide the hard drive towards the gap in the cavity and then remove it from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 935
