Ir para o conteúdo principal
Samsung NP-R540-JA09US Front Panel Replacement
O que você precisa
  1. Samsung NP-R540-JA09US Front Panel Replacement, Battery: passo 1, imagem 1 %32
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
  2. Samsung NP-R540-JA09US Front Panel Replacement: passo 2, imagem 1 %32
    • Pull the two latches outward.
  3. Samsung NP-R540-JA09US Front Panel Replacement: passo 3, imagem 1 %32 Samsung NP-R540-JA09US Front Panel Replacement: passo 3, imagem 2 %32
    • Slide the battery out of the laptop.
  4. Samsung NP-R540-JA09US Front Panel Replacement, Optical Drive: passo 4, imagem 1 %32
    • Remove securing screw with the PH0 head.
  5. Samsung NP-R540-JA09US Front Panel Replacement: passo 5, imagem 1 %32
    • Slide the optical drive out and remove it from the device.
  6. Samsung NP-R540-JA09US Front Panel Replacement, Keyboard: passo 6, imagem 1 %32
    • Remove the two Phillips #0 screws labeled KBD.
    • There are 5 clips along the top of the keyboard. Insert a thin opener tool (iSessamo tool or similar) between each clip and the keyboard tray to release it.
    • Make sure to pry the metal keyboard base and not the keycaps.
  7. Samsung NP-R540-JA09US Front Panel Replacement: passo 8, imagem 1 %32
    • Do not bend your keyboard as shown in this picture.
    • Lift the keyboard up to release catches on the sides, then slide the keyboard towards the screen to slide tabs out of the slots at the bottom.
  8. Samsung NP-R540-JA09US Front Panel Replacement: passo 9, imagem 1 %32 Samsung NP-R540-JA09US Front Panel Replacement: passo 9, imagem 2 %32
    • Disconnect the keyboard cable from the motherboard.
  9. Samsung NP-R540-JA09US Front Panel Replacement, Front Panel: passo 10, imagem 1 %32
    • Remove the two screws with a Phillips #00 screwdriver.
  10. Samsung NP-R540-JA09US Front Panel Replacement: passo 11, imagem 1 %32
    • Remove the highlighted screws with a Phillips #0 Screwdriver.
  11. Samsung NP-R540-JA09US Front Panel Replacement: passo 12, imagem 1 %32 Samsung NP-R540-JA09US Front Panel Replacement: passo 12, imagem 2 %32 Samsung NP-R540-JA09US Front Panel Replacement: passo 12, imagem 3 %32
    • Pry the front panel away from the base with an Opening Tool.
  12. Samsung NP-R540-JA09US Front Panel Replacement: passo 13, imagem 1 %32 Samsung NP-R540-JA09US Front Panel Replacement: passo 13, imagem 2 %32
    • Disconnect the speaker wire from the motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 468
