Introdução
If there is no display on the screen or a black screen when the laptop is on, it may help to replace the screen using this guide. The optical drive, hard drive, and hinges must be removed first.
O que você precisa
Flip the laptop over.
Remove the 6 mm screw with the Phillips #000 screwdriver.
Flip the laptop.
Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
Disconnect the wire from the motherboard by pulling up and away from the laptop.
Remove the four 4 mm screws using Phillips #000 screwdriver.
Remove metal brackets.
