Introdução
If your computer gets stuck or does not open/close smoothly, it may help to replace the hinges using this guide. The optical drive and hard drive must be removed first.
O que você precisa
Flip the laptop over.
Remove the 6 mm screw with the Phillips #000 screwdriver.
Flip the laptop.
Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
Disconnect the wire from the motherboard by pulling up and away from the laptop.
