Introdução
In order to maximize the memory RAM on a computer, it needs to be replaced with a new one.
O que você precisa
Locate the external battery on the bottom side of the device.
Locate the tab on the right side of the battery.
Shift the tab to the left.
Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
After detaching the fan, you are now able to remove the RAM by extending the two side bars out
3 outras pessoas executaram este guia.
