Ir para o conteúdo principal
Samsung NP-NC10-KA02US Hard Drive Replacement
O que você precisa
  1. Samsung NP-NC10-KA02US Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Samsung NP-NC10-KA02US Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Locate the external battery on the bottom side of the device.
    • Locate the tab on the right side of the battery.
    • Shift the tab to the left.
  2. Samsung NP-NC10-KA02US Hard Drive Replacement: passo 2, imagem 1 %32
    • Locate the tab on the left side of the device's battery.
    • Push the left tab to the right.
  3. Samsung NP-NC10-KA02US Hard Drive Replacement: passo 3, imagem 1 %32
    • Pull the battery up from the device.
  4. Samsung NP-NC10-KA02US Hard Drive Replacement, Back Plate: passo 4, imagem 1 %32
    • Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
  5. Samsung NP-NC10-KA02US Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
  6. Samsung NP-NC10-KA02US Hard Drive Replacement: passo 6, imagem 1 %32 Samsung NP-NC10-KA02US Hard Drive Replacement: passo 6, imagem 2 %32
    • Using two plastic opening tools remove the back plate.
    • These plastic opening tools have a flat-head that extends as a wedge which are utilized to separate pressure fit plastic components without causing any damage to them.
    • The back plate is now removed exposing all of the hardware components.
  7. Samsung NP-NC10-KA02US Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32 Samsung NP-NC10-KA02US Hard Drive Replacement, Hard Drive: passo 7, imagem 2 %32
    • Locate the hard drive.
    • Remove the one 3.93 mm screw holding the hard drive in place using a PH1 screw bit.
  8. Samsung NP-NC10-KA02US Hard Drive Replacement: passo 8, imagem 1 %32 Samsung NP-NC10-KA02US Hard Drive Replacement: passo 8, imagem 2 %32
    • Hold the end of the hard drive farthest from where it is connected to the netbook. Then gently pull in the opposite direction of where the hard drive is connected.
    • Your hard drive is now removed.
Conclusão
5 outras pessoas executaram este guia.
Brian Smith
Membro desde: 10/03/16
405 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-1, Sullivan Fall 2016 Membro de USF Tampa, Team 1-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G1
Membros da 3
Autoria de 6 guias
2 comentários
Where can I get the screws from
Lucky Jacob - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 45
Duração total: 6,100
