Ir para o conteúdo principal
Samsung NP-N210-JA02US Wireless Card Replacement
O que você precisa
  1. Samsung NP-N210-JA02US Wireless Card Replacement, Battery: passo 1, imagem 1 %32 Samsung NP-N210-JA02US Wireless Card Replacement, Battery: passo 1, imagem 2 %32
    • Carefully slide both locking pins to the unlocked position.
  2. Samsung NP-N210-JA02US Wireless Card Replacement: passo 2, imagem 1 %32
    • Slide the battery out of its housing.
  3. Samsung NP-N210-JA02US Wireless Card Replacement, Battery Removal: passo 3, imagem 1 %32
    • Remove the following 14 screws:
    • Thirteen 5 mm Phillips #1 screws
    • One 3.5 mm Philips #001 screw
  4. Samsung NP-N210-JA02US Wireless Card Replacement: passo 4, imagem 1 %32
    • Carefully insert the plastic opening tool in the seam between the lower casing and the chrome bezel.
  5. Samsung NP-N210-JA02US Wireless Card Replacement: passo 5, imagem 1 %32
    • Slide the opening tool across all sides of the lower case, and lift it up to remove the case and reveal the internal components.
  6. Samsung NP-N210-JA02US Wireless Card Replacement: passo 6, imagem 1 %32
    • Locate the wireless card.
  7. Samsung NP-N210-JA02US Wireless Card Replacement: passo 7, imagem 1 %32
    • Remove the 3.5 mm Philips #1 screw.
  8. Samsung NP-N210-JA02US Wireless Card Replacement: passo 8, imagem 1 %32 Samsung NP-N210-JA02US Wireless Card Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Carefully with tweezers, lift both connectors to disconnect them from the wireless card.
  9. Samsung NP-N210-JA02US Wireless Card Replacement: passo 9, imagem 1 %32
    • Gently remove the wireless card from its socket.
Conclusão
Afif Chehabaldeen
Membro desde: 10/04/16
401 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-3, Nance Fall 2016 Membro de USF Tampa, Team 1-3, Nance Fall 2016
USFT-NANCE-F16S1G3
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 370
