Ir para o conteúdo principal
Samsung NP-N145-JP02US Screen Replacement
O que você precisa
  1. Samsung NP-N145-JP02US Screen Replacement, Screen: passo 1, imagem 1 %32
    • Before starting replacement, turn off the device and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Screen Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the four black screw covers located at all corners of the screen with tweezers to expose the screws
    • Remove the four 4.5 mm screws located at each corner of the screen by using the Phillips #0 screwdriver.
  3. Samsung NP-N145-JP02US Screen Replacement: passo 3, imagem 1 %32
    • Use a blue prying tool to pry the screen frame off.
    • Unscrew the four 6.5mm screws that are securing the screen using Phillips J0 screwdriver head.
  4. Samsung NP-N145-JP02US Screen Replacement: passo 4, imagem 1 %32 Samsung NP-N145-JP02US Screen Replacement: passo 4, imagem 2 %32 Samsung NP-N145-JP02US Screen Replacement: passo 4, imagem 3 %32
    • Using your fingertips, gently pull screen to pop it out of the frame.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 420
