Ir para o conteúdo principal
Samsung NP-N102S-B05PH Hard Drive Replacement
O que você precisa
  1. Samsung NP-N102S-B05PH Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Before replacing a hard drive, have a backup of original files if files are needed to be recovered afterward.
    • Power down your laptop, and position the laptop with the bottom cover facing upwards.
  2. Samsung NP-N102S-B05PH Hard Drive Replacement: passo 2, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the nine 6.5 mm screws.
  3. Samsung NP-N102S-B05PH Hard Drive Replacement: passo 3, imagem 1 %32
    • Use an opening to pry off the bottom cover, clips.
    • Potential for device damage. Before proceeding, be sure to be grounded, as existing static can be transferred and cause significant damage to the device. Wear an anti-static wristband for additional protection.
  4. Samsung NP-N102S-B05PH Hard Drive Replacement: passo 4, imagem 1 %32 Samsung NP-N102S-B05PH Hard Drive Replacement: passo 4, imagem 2 %32 Samsung NP-N102S-B05PH Hard Drive Replacement: passo 4, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the four 4.5 mm bracket screws holding the hard drive onto the motherboard.
    • Take care not to remove the screws holding the bracket to the motherboard, as you will need that bracket to attach the next hard drive.
  5. Samsung NP-N102S-B05PH Hard Drive Replacement: passo 5, imagem 1 %32 Samsung NP-N102S-B05PH Hard Drive Replacement: passo 5, imagem 2 %32 Samsung NP-N102S-B05PH Hard Drive Replacement: passo 5, imagem 3 %32
    • Lift the hard drive up and gently pull off the SATA cable that is currently connected to the board.
    • The hard drive is now fully removed from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Daniel Rudzik
Membro desde: 10/04/16
349 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 2-4, Nance Fall 2016 Membro de USF Tampa, Team 2-4, Nance Fall 2016
USFT-NANCE-F16S2G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 1,563
