Ir para o conteúdo principal
Samsung NP-130-JA01US Keyboard Replacement
O que você precisa
  1. Samsung NP-130-JA01US Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
  2. Samsung NP-130-JA01US Keyboard Replacement: passo 2, imagem 1 %32 Samsung NP-130-JA01US Keyboard Replacement: passo 2, imagem 2 %32
    • Slide the left and right slider buttons fully away from each other.
  3. Samsung NP-130-JA01US Keyboard Replacement: passo 3, imagem 1 %32
    • Pull the battery out of the computer.
  4. Samsung NP-130-JA01US Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Samsung NP-130-JA01US Keyboard Replacement, Keyboard: passo 4, imagem 2 %32
    • Using a Phillips 1 screwdriver carefully remove all 12 screws of the back cover.
    • The screws are Phillips 1 (PH 1) with a length of 60 millimeters (mm)
    • Do not force the screwdriver as you might damage the screws.
  5. Samsung NP-130-JA01US Keyboard Replacement: passo 5, imagem 1 %32 Samsung NP-130-JA01US Keyboard Replacement: passo 5, imagem 2 %32 Samsung NP-130-JA01US Keyboard Replacement: passo 5, imagem 3 %32
    • Flip the computer and open the front cover so that the screen is looking at you.
    • Using a Metal Spudger and your dominant hand, carefully separate the keyboard from the computer frame.
    • Do not force the keyboard out, it should come out easily with the help of the Metal Spudger
  6. Samsung NP-130-JA01US Keyboard Replacement: passo 6, imagem 1 %32 Samsung NP-130-JA01US Keyboard Replacement: passo 6, imagem 2 %32 Samsung NP-130-JA01US Keyboard Replacement: passo 6, imagem 3 %32
    • Flip the keyboard over.
    • Notice the lock mechanism (marked in red) that holds the cables to the computer.
    • With your fingers, flip the mechanism over before pulling the cables out.
    • Second picture shows the unlocked position.
    • Carefully pull the cables out of the computer.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 9-6, Lacy Fall 2016 Membro de USF Tampa, Team 9-6, Lacy Fall 2016
USFT-LACY-F16S9G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 300
