Ir para o conteúdo principal
Samsung NP-130-JA01US Fan Replacement
O que você precisa
  1. Samsung NP-130-JA01US Fan Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
  2. Samsung NP-130-JA01US Fan Replacement: passo 2, imagem 1 %32 Samsung NP-130-JA01US Fan Replacement: passo 2, imagem 2 %32
    • Slide the left and right slider buttons fully away from each other.
  3. Samsung NP-130-JA01US Fan Replacement: passo 3, imagem 1 %32
    • Pull the battery out of the computer.
  4. Samsung NP-130-JA01US Fan Replacement, Fan: passo 4, imagem 1 %32 Samsung NP-130-JA01US Fan Replacement, Fan: passo 4, imagem 2 %32
    • Using a Phillips 1 screwdriver, carefully remove all 12 screws of the back cover.
    • The screws are Phillips 1 (PH 1) with a length of 60 millimeters (mm)
    • Do not force the screwdriver as you might damage the screws.
  5. Samsung NP-130-JA01US Fan Replacement: passo 5, imagem 1 %32 Samsung NP-130-JA01US Fan Replacement: passo 5, imagem 2 %32 Samsung NP-130-JA01US Fan Replacement: passo 5, imagem 3 %32
    • With the plastic opening tool, carefully separate the back cover from the computer frame.
    • Starting at one of the corners of the computer, work your way around the edge until you reach the other corner.
    • Do not attempt to pry it open, putting too much force into one location might damage the computer.
    • As you go around the sides of the computer, free the inside latches with the plastic opening tool.
    • Once you have an opening, carefully use your hands to separate the back cover.
  6. Samsung NP-130-JA01US Fan Replacement: passo 6, imagem 1 %32 Samsung NP-130-JA01US Fan Replacement: passo 6, imagem 2 %32
    • Locate the fan (marked in a red square).
  7. Samsung NP-130-JA01US Fan Replacement: passo 7, imagem 1 %32 Samsung NP-130-JA01US Fan Replacement: passo 7, imagem 2 %32 Samsung NP-130-JA01US Fan Replacement: passo 7, imagem 3 %32
    • Using a Phillips 1 screwdriver, remove the screw marked in a red circle.
    • The screw is a Phillips 1 (PH 1) with a length of 40 millimeters (mm)
    • Do not use too much force on the screw driver, you might damage the screw.
    • Using your hands, carefully unplug the cords marked in a green square.
  8. Samsung NP-130-JA01US Fan Replacement: passo 8, imagem 1 %32 Samsung NP-130-JA01US Fan Replacement: passo 8, imagem 2 %32
    • Carefully remove the fan.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 9-6, Lacy Fall 2016 Membro de USF Tampa, Team 9-6, Lacy Fall 2016
USFT-LACY-F16S9G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 263
