Introdução
Replace or upgrade your Samsung NP N310 HAA2US hard drive with any compatible hard drive. A new hard drive can give a user more space and also provide better performance.
O que você precisa
Slide the battery switch to the unlock symbol, and the battery will pop up.
Remove the battery.
Locate, and unscrew the 11 Phillips 8mm back cover screws, and 1 Phillips 5mm screw on the RAM cover. Use a #1 Philips screw driver to remove the screws.
Unscrew the 3 Phillips 3.5 mm screws. Use a size 1 Phillips screwdriver.
Lift the hardrive.
Pull the hard drive out.
