Ir para o conteúdo principal
Samsung NP N310 HAA2US Back Panel Replacement
O que você precisa
  1. Samsung NP N310 HAA2US Back Panel Replacement, Battery: passo 1, imagem 1 %32 Samsung NP N310 HAA2US Back Panel Replacement, Battery: passo 1, imagem 2 %32 Samsung NP N310 HAA2US Back Panel Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the laptop is powered off, and unplugged before removing the battery.
    • Slide the battery switch to the unlock symbol, and the battery will pop up.
    • Remove the battery.
  2. Samsung NP N310 HAA2US Back Panel Replacement, Back Panel: passo 2, imagem 1 %32 Samsung NP N310 HAA2US Back Panel Replacement, Back Panel: passo 2, imagem 2 %32
    • Locate, and unscrew the 11 Phillips 8mm back cover screws, and 1 Phillips 5mm screw on the RAM cover. Use a #1 Philips screw driver to remove the screws.
    • If there are rubber pads covering the screws, use a spudger to remove the rubber pads.
  3. Samsung NP N310 HAA2US Back Panel Replacement: passo 3, imagem 1 %32 Samsung NP N310 HAA2US Back Panel Replacement: passo 3, imagem 2 %32 Samsung NP N310 HAA2US Back Panel Replacement: passo 3, imagem 3 %32
    • Insert the plastic opening tool in the break between the back panel, and the keyboard.
    • Drag the opening tool around the edge to separate it.
    • Pull the back panel off of the laptop.
Conclusão
Amir Afridi
Membro desde: 09/29/16
626 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 4-1, Passmore Fall 2016 Membro de USF Tampa, Team 4-1, Passmore Fall 2016
USFT-PASSMORE-F16S4G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 16
Duração total: 326
