Introdução
Ir para o passo 1 ↓This guide will allow the user to install a 2GB RAM to increase the laptops ability to run multiple programs and will improve overall efficiency.
O que você precisa
Turn off the computer.
Disconnect the charging cable from the laptop.
Flip the laptop upside down with the front face down on a flat surface.
Using the Phillip's 00 screwdriver, unscrew the fourteen 7mm screws until the back panel comes loose.
Using your hands, push the two metal clip holders on each side away from the RAM till you hear a clicking sound.
Uma outra pessoa concluiu este guia.
1Comentário do guia
There is no need to open the entire casing. There is a special lid on the back that covers the SODIMM for easy access. It can be replaced removing only one screw.
