Introdução
This will provide the necessary steps to remove the keyboard from the laptop. This process can be time consuming and takes a lot of patience when it comes to removing they keyboard without damaging it. Make sure to take your time and follow the instructions completely.
O que você precisa
Turn off the computer.
Disconnect the charging cable from the laptop.
Flip the laptop upside down with the front face down on a flat surface.
Using the Phillip's 00 screwdriver, unscrew the fourteen 7mm screws until the back panel comes loose.
Double check that you removed the three 7mm screws for the keyboard in the process of removing the back panel
