Ir para o conteúdo principal
Samsung N150 Plus Battery Replacement
  1. Samsung N150 Plus Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down with the front face down on a flat surface.
  2. Samsung N150 Plus Battery Replacement: passo 2, imagem 1 %32 Samsung N150 Plus Battery Replacement: passo 2, imagem 2 %32
    • Slide the left and right switch to the "unlocked" position.
  3. Samsung N150 Plus Battery Replacement: passo 3, imagem 1 %32 Samsung N150 Plus Battery Replacement: passo 3, imagem 2 %32
    • While holding the left and right hand switches in the "unlocked" position, push the battery away from the computer.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 46
Ao todo: 2,434
