Ir para o conteúdo principal
Samsung Mythic SGH-a897 Speaker Replacement
O que você precisa
  1. Samsung Mythic SGH-a897 Speaker Replacement, Battery: passo 1, imagem 1 %32
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Speaker Replacement: passo 2, imagem 1 %32
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Speaker Replacement, Rear Case: passo 3, imagem 1 %32
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Speaker Replacement: passo 4, imagem 1 %32
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 Speaker Replacement, Speaker: passo 5, imagem 1 %32 Samsung Mythic SGH-a897 Speaker Replacement, Speaker: passo 5, imagem 2 %32
    • Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out.
Conclusão
Morgan Yost
Membro desde: 04/08/13
46 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 17-1, Regan Spring 2013 Membro de Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 260
