Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will show you how to get access to the LCD screen in order to clean or replace it.
O que você precisa
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
Carefully remove the camera from the phone's motherboard.
Hold the phone by the black plastic at the ends and slightly bend them down so that the middle of the phone is the highest point. Apply pressure slowly until the until the grey portion pops off.
