Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to replace the daughterboard in the Samsung Mythic SGH-a897.
O que você precisa
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
Carefully remove the camera from the phone's motherboard.
use the tweezers to unclip the connector as shown.
This is the only attachment that is holding the daughterboard to the motherboard. You can no remove the daughterboard.
