Introdução
This guide will require you to disassemble the back and side panel of the printer. You will need to refer to the Removing Samsung ML2510 Back Panel guide in order to complete the task.
O que você precisa
Remove the top hinged panel by taking out the pins at the bottom of this panel.
Locate the holes on the panel that are attached to the main body.
Remove the front panel by gently moving the holes from the pegs one by one.
