Ir para o conteúdo principal
Samsung ML2510 Power Button Replacement
O que você precisa
  1. Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: passo 1, imagem 1 %32 Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: passo 1, imagem 2 %32 Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: passo 1, imagem 3 %32
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Power Button Replacement: passo 2, imagem 1 %32
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Power Button Replacement: passo 3, imagem 1 %32 Samsung ML2510 Power Button Replacement: passo 3, imagem 2 %32 Samsung ML2510 Power Button Replacement: passo 3, imagem 3 %32
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Power Button Replacement, Power Button: passo 4, imagem 1 %32 Samsung ML2510 Power Button Replacement, Power Button: passo 4, imagem 2 %32 Samsung ML2510 Power Button Replacement, Power Button: passo 4, imagem 3 %32
    • Remove the front panel by gently separating the holes on the panel from the pegs attached to the main printer body.
  5. Samsung ML2510 Power Button Replacement: passo 5, imagem 1 %32
    • Using a Phillips #2 screwdriver, remove both 1" screws on the front face of the printer.
  6. Samsung ML2510 Power Button Replacement: passo 6, imagem 1 %32 Samsung ML2510 Power Button Replacement: passo 6, imagem 2 %32 Samsung ML2510 Power Button Replacement: passo 6, imagem 3 %32
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat the last step to free the opposite side of the top panel.
    • Lift the top panel from the front to remove it entirely.
    • Turn over the top panel to reveal the button on the underside of the panel.
  7. Samsung ML2510 Power Button Replacement: passo 7, imagem 1 %32
    • Using a Phillips #2 screwdriver, remove both 1" screws that secure the button to the underside of the top panel.
  8. Samsung ML2510 Power Button Replacement: passo 8, imagem 1 %32 Samsung ML2510 Power Button Replacement: passo 8, imagem 2 %32
    • Remove the clear plastic piece and the orange button from the panel.
    • Remove the orange button and the spring from the clear plastic holder.
    • Replace the button and reassemble the printer following the directions in reverse order.
Linha de Chegada
bbaustin
Membro desde: 10/12/11
268 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 17-18, Regan Fall 2011 Membro de Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 3,346
