Introdução
This guide will help you to replace the power button of your Samsung ML2510 laser printer.
O que você precisa
Remove the top hinged panel by taking out the pins at the bottom of this panel.
Remove the front panel by gently separating the holes on the panel from the pegs attached to the main printer body.
Quase terminado!
Linha de Chegada
