Ir para o conteúdo principal
Samsung LN-T5265F T-Con Board Replacement
O que você precisa
  1. Samsung LN-T5265F T-Con Board Replacement, Stand: passo 1, imagem 1 %32
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
    • Slide the stand out from the bottom of the TV.
  2. Samsung LN-T5265F T-Con Board Replacement, Rear Case: passo 3, imagem 1 %32 Samsung LN-T5265F T-Con Board Replacement, Rear Case: passo 3, imagem 2 %32
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
  3. Samsung LN-T5265F T-Con Board Replacement, T-Con Board: passo 4, imagem 1 %32 Samsung LN-T5265F T-Con Board Replacement, T-Con Board: passo 4, imagem 2 %32
    • The Timing Controller (T-Con) board is located at the top center behind a metal shield.
    • Remove four Phillips screws.
    • Tilt the metal shield towards the top of the TV and lift away.
  4. Samsung LN-T5265F T-Con Board Replacement: passo 5, imagem 1 %32
    • Disconnect the two ribbon cables at the top by flipping up the retaining flaps and sliding the ribbons straight up towards the top of the TV.
  5. Samsung LN-T5265F T-Con Board Replacement: passo 6, imagem 1 %32
    • Disconnect the bottom ribbon cable by depressing the two buttons on either side of the connector and sliding down towards the bottom of the TV.
Conclusão
3 outras pessoas executaram este guia.
Steven Carlton
Membro desde: 08/19/13
606 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 21
Duração total: 10,078
