Ir para o conteúdo principal
Samsung LA40R81BD 40in LCD TV Remote Control Disassembly
O que você precisa
  1. Samsung LA40R81BD 40in LCD TV Remote Control Disassembly, Remote control: passo 1, imagem 1 %32 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly, Remote control: passo 1, imagem 2 %32 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly, Remote control: passo 1, imagem 3 %32
    • Remove batteries before you disassemble the remote
    • Use a case opening tool to gently split the upper and lower case
    • Work around the entire case until the 2 halves come apart completely
  2. Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: passo 2, imagem 1 %32 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: passo 2, imagem 2 %32
    • Release the circuit board by gently pushing the plastic tab away from the board
    • Use minimal force to avoid breaking it
    • Lift circuit board off top cover to expose the rubber button membrane
    • Lift off the rubber button membrane
  3. Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: passo 3, imagem 1 %32 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: passo 3, imagem 2 %32
    • During reassembly make sure that you correctly place the battery cover retainer on the read case
  4. Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: passo 4, imagem 1 %32 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: passo 4, imagem 2 %32
    • When placing rear cover back onto the assembled top cover make sure you correctly align the battery terminals with the slots in the cover
Conclusão
9 outras pessoas executaram este guia.
Richdave
Membro desde: 04/09/10
32.063 Reputação
Autoria de 30 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.534 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 27
Últimos 30 dias: 110
Duração total: 36,222
