Ir para o conteúdo principal
Samsung L100 flash assembly replacement
O que você precisa
  1. Samsung L100 flash assembly replacement, Removing Back Cover: passo 1, imagem 1 %32 Samsung L100 flash assembly replacement, Removing Back Cover: passo 1, imagem 2 %32 Samsung L100 flash assembly replacement, Removing Back Cover: passo 1, imagem 3 %32
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Samsung L100 flash assembly replacement: passo 2, imagem 1 %32 Samsung L100 flash assembly replacement: passo 2, imagem 2 %32
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Samsung L100 flash assembly replacement: passo 3, imagem 1 %32 Samsung L100 flash assembly replacement: passo 3, imagem 2 %32 Samsung L100 flash assembly replacement: passo 3, imagem 3 %32
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Samsung L100 flash assembly replacement: passo 4, imagem 1 %32
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Samsung L100 flash assembly replacement: passo 5, imagem 1 %32
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
  6. Samsung L100 flash assembly replacement, Flash Circuit Board: passo 6, imagem 1 %32
    • Remove the screws holding the circuit board.
    • After you remove the screws, carefully remove the circuit board.
  7. Samsung L100 flash assembly replacement: passo 7, imagem 1 %32 Samsung L100 flash assembly replacement: passo 7, imagem 2 %32
    • Remove the front cover, it comes off easily.
    • Buttons might fall out when you remove the front cover.
  8. Samsung L100 flash assembly replacement: passo 8, imagem 1 %32
    • Face camera towards you.
    • Remove the two screws from circuit board on the left side of the lens.
  9. Samsung L100 flash assembly replacement: passo 9, imagem 1 %32
    • Carefully hold up the circuit board, while it's still connected to the camera.
    • Remove all five screws that's on top of the camera.
  10. Samsung L100 flash assembly replacement: passo 10, imagem 1 %32 Samsung L100 flash assembly replacement: passo 10, imagem 2 %32 Samsung L100 flash assembly replacement: passo 10, imagem 3 %32
    • Carefully push up the top of the circuit board.
    • Pull up flash circuit board from top of camera.
Conclusão
Uma outra pessoa concluiu este guia.
Adriel
Membro desde: 04/15/10
123 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-17, Maness Spring 2010 Membro de Cal Poly, Team 6-17, Maness Spring 2010
CPSU-MANESS-S10S6G17
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 4,003
