Introdução
If camera lens jams or breaks, this guide will help you replace it.
O que você precisa
Remove the six external screws from the camera using a Phillips #0 screwdriver.
After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
5 outras pessoas executaram este guia.
