Ir para o conteúdo principal
Samsung Juke SCH-u470 Keyboard Replacement
O que você precisa
  1. Samsung Juke SCH-u470 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Press and hold down the button on the bottom side of the phone with your finger.
  2. Samsung Juke SCH-u470 Keyboard Replacement: passo 2, imagem 1 %32 Samsung Juke SCH-u470 Keyboard Replacement: passo 2, imagem 2 %32
    • While holding the button down, remove the back cover of the phone.
  3. Samsung Juke SCH-u470 Keyboard Replacement, Camera/Speaker: passo 3, imagem 1 %32
    • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
  4. Samsung Juke SCH-u470 Keyboard Replacement: passo 4, imagem 1 %32
    • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
  5. Samsung Juke SCH-u470 Keyboard Replacement: passo 5, imagem 1 %32 Samsung Juke SCH-u470 Keyboard Replacement: passo 5, imagem 2 %32 Samsung Juke SCH-u470 Keyboard Replacement: passo 5, imagem 3 %32
    • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
    • Failure to open USB port cover at this stage may result in damaging the device.
  6. Samsung Juke SCH-u470 Keyboard Replacement: passo 6, imagem 1 %32
    • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
  7. Samsung Juke SCH-u470 Keyboard Replacement: passo 7, imagem 1 %32 Samsung Juke SCH-u470 Keyboard Replacement: passo 7, imagem 2 %32
    • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
    • Practice caution to prevent damage to the attaching ribbon.
  8. Samsung Juke SCH-u470 Keyboard Replacement: passo 8, imagem 1 %32 Samsung Juke SCH-u470 Keyboard Replacement: passo 8, imagem 2 %32
    • Use the iFixit opening tool to gently pry the camera/speaker off.
  9. Samsung Juke SCH-u470 Keyboard Replacement, Motherboard: passo 9, imagem 1 %32 Samsung Juke SCH-u470 Keyboard Replacement, Motherboard: passo 9, imagem 2 %32
    • Use the iFixit opening tool to remove the yellow tab on the motherboard.
  10. Samsung Juke SCH-u470 Keyboard Replacement: passo 10, imagem 1 %32 Samsung Juke SCH-u470 Keyboard Replacement: passo 10, imagem 2 %32
    • Use the iFixit opening tool to remove the other orange tab to free the motherboard.
  11. Samsung Juke SCH-u470 Keyboard Replacement: passo 11, imagem 1 %32 Samsung Juke SCH-u470 Keyboard Replacement: passo 11, imagem 2 %32 Samsung Juke SCH-u470 Keyboard Replacement: passo 11, imagem 3 %32
    • To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
    • Do not be alarmed if the volume and hold buttons are removed from the motherboard.
  12. Samsung Juke SCH-u470 Keyboard Replacement, Keyboard: passo 12, imagem 1 %32 Samsung Juke SCH-u470 Keyboard Replacement, Keyboard: passo 12, imagem 2 %32 Samsung Juke SCH-u470 Keyboard Replacement, Keyboard: passo 12, imagem 3 %32
    • Open/swivel the phone so the back of the LCD panel is visible.
    • Use the iFixit opening tool to pry the keypad from the hinge on the back of the device.
    • A moderate amount of force may need to be applied.
Conclusão
Uma outra pessoa concluiu este guia.
Renee Kuzniar
Membro desde: 04/13/10
94 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-18, Maness Spring 2010 Membro de Cal Poly, Team 6-18, Maness Spring 2010
CPSU-MANESS-S10S6G18
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,954
