Ferramentas
Peças
Nenhum componente especificado.
Locate the button on the bottom of the phone. Once located, press and hold the button down.
Use the size 00 Phillips screwdriver to remove the four screws located on the back of the phone. These screws are circled in yellow in the given image.
Open/swivel the phone so the back of the LCD panel is visible.
Use the iPod opening tool to pry the keypad from the hinge on the back of the device.
Using your fingernail, remove the stickers covering the screws on the back of the LCD casing.
Using a phillips 00 screwdriver, remove all six screws on the back of the device.
Using tweezers, grip the red and blue wires that attach the audio earpiece to the outer casing and pull.
2 outras pessoas concluíram este guia.
