Ir para o conteúdo principal
Samsung Juke Camera/Speaker Replacement
O que você precisa
  1. Samsung Juke Camera/Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Press and hold down the button on the bottom side of the phone with your finger.
  2. Samsung Juke Camera/Speaker Replacement: passo 2, imagem 1 %32 Samsung Juke Camera/Speaker Replacement: passo 2, imagem 2 %32
    • While holding the button down, remove the back cover of the phone.
  3. Samsung Juke Camera/Speaker Replacement, Camera/Speaker: passo 3, imagem 1 %32
    • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
  4. Samsung Juke Camera/Speaker Replacement: passo 4, imagem 1 %32
    • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
  5. Samsung Juke Camera/Speaker Replacement: passo 5, imagem 1 %32 Samsung Juke Camera/Speaker Replacement: passo 5, imagem 2 %32 Samsung Juke Camera/Speaker Replacement: passo 5, imagem 3 %32
    • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
    • Failure to open USB port cover at this stage may result in damaging the device.
  6. Samsung Juke Camera/Speaker Replacement: passo 6, imagem 1 %32
    • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
  7. Samsung Juke Camera/Speaker Replacement: passo 7, imagem 1 %32 Samsung Juke Camera/Speaker Replacement: passo 7, imagem 2 %32
    • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
    • Practice caution to prevent damage to the attaching ribbon.
  8. Samsung Juke Camera/Speaker Replacement: passo 8, imagem 1 %32 Samsung Juke Camera/Speaker Replacement: passo 8, imagem 2 %32
    • Use the iFixit opening tool to gently pry the camera/speaker off.
Conclusão
Uma outra pessoa concluiu este guia.
Renee Kuzniar
Membro desde: 04/13/10
94 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-18, Maness Spring 2010 Membro de Cal Poly, Team 6-18, Maness Spring 2010
CPSU-MANESS-S10S6G18
Membros da 3
Autoria de 12 guias
2 comentários
Hey! Thank you for posting such an in-depth guide to repair and replacement for this phone!! I just recently booted mine back up again, and it's truly been a time capsule of what life was like back then. Everything has been running pretty smoothly up until I tested my speakers. Weirdly, it plays the start up/shut down sounds perfectly, but won't play any other sounds/songs even with the volume all the way up. Camera works just fine, so wondering if you have any suggestions outside of replacement? I still have to find an aux cord that fits to see if sound can come out of there; will keep y'all posted on that. Otherwise, I really appreciate any feedback y'all may have. Thanks again for the guidance!
Jess Garcia - Responder
Update: Found an aux cord that fits, it still doesn't emit any sound. I noticed how the aux cord doesn't feel fully secure on the inside, it kinda jiggles around. Let me know if there's any internal fixes I can try for this. Much appreciated <3
Jess Garcia -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 3,527
