Ir para o conteúdo principal
Samsung Jack Speaker Replacement
O que você precisa
  1. Samsung Jack Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Speaker Replacement: passo 2, imagem 1 %32
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Speaker Replacement, Rear Case: passo 3, imagem 1 %32
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Speaker Replacement: passo 4, imagem 1 %32 Samsung Jack Speaker Replacement: passo 4, imagem 2 %32 Samsung Jack Speaker Replacement: passo 4, imagem 3 %32
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Speaker Replacement: passo 5, imagem 1 %32
    • Lift the rear case off of the phone.
  6. Samsung Jack Speaker Replacement, Speaker: passo 6, imagem 1 %32
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
  7. Samsung Jack Speaker Replacement: passo 7, imagem 1 %32 Samsung Jack Speaker Replacement: passo 7, imagem 2 %32
    • Use the spudger to detach the speaker ribbon cable.
  8. Samsung Jack Speaker Replacement: passo 8, imagem 1 %32
    • Lift the speaker out of its compartment.
Conclusão
Uma outra pessoa concluiu este guia.
Paul Piller
Membro desde: 04/12/11
56 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 24-57, Amido Spring 2011 Membro de Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 79
Ao todo: 1,988
