Ir para o conteúdo principal
Samsung Jack Rear Case Replacement
O que você precisa
  1. Samsung Jack Rear Case Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Rear Case Replacement: passo 2, imagem 1 %32
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Rear Case Replacement, Rear Case: passo 3, imagem 1 %32
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Rear Case Replacement: passo 4, imagem 1 %32 Samsung Jack Rear Case Replacement: passo 4, imagem 2 %32 Samsung Jack Rear Case Replacement: passo 4, imagem 3 %32
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Rear Case Replacement: passo 5, imagem 1 %32
    • Lift the rear case off of the phone.
Conclusão
Paul Piller
Membro desde: 04/12/11
56 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 24-57, Amido Spring 2011 Membro de Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,155
