Ir para o conteúdo principal
Samsung Jack Antenna Replacement
O que você precisa
  1. Samsung Jack Antenna Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
    Pergunte ao FixBot
    Comentar
  2. Samsung Jack Antenna Replacement: passo 2, imagem 1 %32
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
    Pergunte ao FixBot
    Comentar
  3. Samsung Jack Antenna Replacement, Rear Case: passo 3, imagem 1 %32
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Samsung Jack Antenna Replacement: passo 4, imagem 1 %32 Samsung Jack Antenna Replacement: passo 4, imagem 2 %32 Samsung Jack Antenna Replacement: passo 4, imagem 3 %32
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
    Pergunte ao FixBot
    Comentar
  5. Samsung Jack Antenna Replacement: passo 5, imagem 1 %32
    • Lift the rear case off of the phone.
    Pergunte ao FixBot
    Comentar
  6. Samsung Jack Antenna Replacement, Antenna: passo 6, imagem 1 %32
    • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Samsung Jack Antenna Replacement: passo 7, imagem 1 %32 Samsung Jack Antenna Replacement: passo 7, imagem 2 %32 Samsung Jack Antenna Replacement: passo 7, imagem 3 %32
    • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
    • Use a spudger to remove the wire connector under the antenna.
    Pergunte ao FixBot
    Comentar
Conclusão
Paul Piller
Membro desde: 04/12/11
56 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 24-57, Amido Spring 2011 Membro de Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 50
Ao todo: 2,658
