Ir para o conteúdo principal
Samsung Instinct Camera Replacement
O que você precisa
  1. Samsung Instinct Camera Replacement, Battery: passo 1, imagem 1 %32
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
    Pergunte ao FixBot
  2. Samsung Instinct Camera Replacement: passo 2, imagem 1 %32
    • Holding the phone firmly, use the notches to grip and lift up the battery.
    Pergunte ao FixBot
  3. Samsung Instinct Camera Replacement, Back Case: passo 3, imagem 1 %32
    • Remove the four 4.45mm screws at the corners of the phone.
    Pergunte ao FixBot
  4. Samsung Instinct Camera Replacement: passo 4, imagem 1 %32 Samsung Instinct Camera Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
    Pergunte ao FixBot
  5. Samsung Instinct Camera Replacement: passo 5, imagem 1 %32
    • Lift the casing off of the phone.
    Pergunte ao FixBot
  6. Samsung Instinct Camera Replacement, Antenna: passo 6, imagem 1 %32
    • With the screws removed, locate the antenna.
    Pergunte ao FixBot
  7. Samsung Instinct Camera Replacement: passo 7, imagem 1 %32
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
    Pergunte ao FixBot
  8. Samsung Instinct Camera Replacement: passo 8, imagem 1 %32
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
    Pergunte ao FixBot
  9. Samsung Instinct Camera Replacement: passo 9, imagem 1 %32
    • Gently lift up on the antenna and remove it from the back of the device.
    Pergunte ao FixBot
  10. Samsung Instinct Camera Replacement, Front Case: passo 10, imagem 1 %32
    • Remove the two 3.50mm screws connecting the motherboard to the case.
    Pergunte ao FixBot
  11. Samsung Instinct Camera Replacement: passo 11, imagem 1 %32 Samsung Instinct Camera Replacement: passo 11, imagem 2 %32 Samsung Instinct Camera Replacement: passo 11, imagem 3 %32
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
    Pergunte ao FixBot
  12. Samsung Instinct Camera Replacement: passo 12, imagem 1 %32
    • Lift out the top right ribbon from its slot on the motherboard.
    Pergunte ao FixBot
  13. Samsung Instinct Camera Replacement: passo 13, imagem 1 %32 Samsung Instinct Camera Replacement: passo 13, imagem 2 %32
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
    Pergunte ao FixBot
  14. Samsung Instinct Camera Replacement: passo 14, imagem 1 %32
    • Lift the motherboard away from the front casing.
    Pergunte ao FixBot
  15. Samsung Instinct Camera Replacement: passo 15, imagem 1 %32
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
    Pergunte ao FixBot
  16. Samsung Instinct Camera Replacement, Motherboard: passo 16, imagem 1 %32 Samsung Instinct Camera Replacement, Motherboard: passo 16, imagem 2 %32 Samsung Instinct Camera Replacement, Motherboard: passo 16, imagem 3 %32
    • Using the plastic opener tool, gently pry away the side strip control buttons from the metal center frame.
    • There are three strips total: one on the right, left, and top of the phone.
    Pergunte ao FixBot
  17. Samsung Instinct Camera Replacement: passo 17, imagem 1 %32
    • Using the plastic opener tool, pry the speaker connector away from the back of the motherboard.
    Pergunte ao FixBot
  18. Samsung Instinct Camera Replacement: passo 18, imagem 1 %32
    • Using the plastic opener tool, remove the speaker from its setting.
    • Pry where the wire enters the speaker.
    • The speaker has adhesive on the bottom, thus removing it will require a bit of wiggling.
    Pergunte ao FixBot
  19. Samsung Instinct Camera Replacement: passo 19, imagem 1 %32
    • Gently lift the motherboard from the center frame.
    Pergunte ao FixBot
  20. Samsung Instinct Camera Replacement, Camera: passo 20, imagem 1 %32
    • Once the motherboard is removed from the frame, use the pry tool to remove the camera.
    • Insert the pry bar between the camera and the frame then lift up.
    • The camera is held in by adhesive so it will require some force to remove.
    • You have now successfully removed the camera from your Samsung Instinct.
    Pergunte ao FixBot
Conclusão
Patrick
Membro desde: 10/11/11
75 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-13, Regan Fall 2011 Membro de Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 8
Últimos 30 dias: 91
Ao todo: 1,157
