Pular para o conteúdo principal
Introdução
This guide shows how to take out the antenna so that a replacement can be installed.
Peças
Nenhum componente especificado.
  1. Apply pressure to the back cover and slide it forward towards the camera.
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Holding the phone firmly, use the notches to grip and lift up the battery.
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Remove the four 4.45mm screws at the corners of the phone.
    • Remove the four 4.45mm screws at the corners of the phone.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  5. Use the plastic opening tool to unhinge the locks around the edges of the phone. Do not worry about the inner components of the phone; they are not connected to this case.
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  6. Lift the casing off of the phone.
    • Lift the casing off of the phone.
  7. With the screws removed, locate the antenna.
    • With the screws removed, locate the antenna.
  8. Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  9. Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  10. Gently lift up on the antenna and remove it from the back of the device.
    • Gently lift up on the antenna and remove it from the back of the device.
Conclusão
Jimmy Kuo
Membro desde: 10-10-2011
14 reputação
2 Guias de autoria
Equipe
Cal Poly, Team 3-13, Regan Fall 2011 Membro de Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Membros
16 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 968
