Introdução
How to remove & replace the phone's back speaker.
O que você precisa
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
Remove the back speaker by carefully prying it upwards with the spudger.
The speaker will still be attached to the circuit board by a wire and a small piece of clear plastic.
Disconnect the speaker by lifting the clear plastic piece at the end of the wire.
3 outras pessoas executaram este guia.
