Ir para o conteúdo principal
Samsung Impression Back Speaker Replacement
O que você precisa
  1. Samsung Impression Back Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
    Pergunte ao FixBot
    Comentar
  2. Samsung Impression Back Speaker Replacement: passo 2, imagem 1 %32 Samsung Impression Back Speaker Replacement: passo 2, imagem 2 %32
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
    Pergunte ao FixBot
    Comentar
  3. Samsung Impression Back Speaker Replacement, Back Cover: passo 3, imagem 1 %32
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
    Pergunte ao FixBot
    Comentar
  4. Samsung Impression Back Speaker Replacement: passo 4, imagem 1 %32
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
    Pergunte ao FixBot
    Comentar
  5. Samsung Impression Back Speaker Replacement, Back Speaker: passo 5, imagem 1 %32
    • Carefully pry the back speaker upwards with a spudger.
    • The speaker is still connected to the circuit board by a wire and small piece of clear plastic.
    • Disconnect the speaker by lifting the clear plastic piece attached to the wire.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Ross McKelvie
Membro desde: 04/18/11
196 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 8-10, Regan Spring 2011 Membro de Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Membros
Autoria de 23 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 33
Ao todo: 2,414
