Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
Insert the tip of the spudger on the left side of the battery, opposite the direction of the white arrow.
Pry the battery free. It will pivot in the direction of the white arrow.
Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
Remove the back cover by gently prying around the top and bottom edges with the spudger.
The side buttons will become loose and will fall out, so put these in a safe place.
