Introdução
How to remove & replace the phone's antenna.
O que você precisa
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
To free the circuit board, remove the black wire that is holding it down.
Remove the 3.9mm screw holding the bottom black piece (antenna assembly) into place.
The antenna assembly will snap off.
Uma outra pessoa concluiu este guia.
