Ir para o conteúdo principal
Samsung HMX-W300 USB Port Replacement
O que você precisa
  1. Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: passo 1, imagem 1 %32 Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: passo 1, imagem 2 %32 Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: passo 1, imagem 3 %32
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 USB Port Replacement: passo 2, imagem 1 %32 Samsung HMX-W300 USB Port Replacement: passo 2, imagem 2 %32
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 USB Port Replacement: passo 3, imagem 1 %32 Samsung HMX-W300 USB Port Replacement: passo 3, imagem 2 %32 Samsung HMX-W300 USB Port Replacement: passo 3, imagem 3 %32
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 USB Port Replacement: passo 4, imagem 1 %32 Samsung HMX-W300 USB Port Replacement: passo 4, imagem 2 %32 Samsung HMX-W300 USB Port Replacement: passo 4, imagem 3 %32
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 USB Port Replacement: passo 5, imagem 1 %32 Samsung HMX-W300 USB Port Replacement: passo 5, imagem 2 %32 Samsung HMX-W300 USB Port Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 USB Port Replacement, Battery: passo 6, imagem 1 %32 Samsung HMX-W300 USB Port Replacement, Battery: passo 6, imagem 2 %32
    • Remove the four screws from the battery housing using a Phillips #00 screwdriver.
  7. Samsung HMX-W300 USB Port Replacement: passo 7, imagem 1 %32
    • Use the iFixit opening tool to pry the battery housing open.
  8. Samsung HMX-W300 USB Port Replacement: passo 8, imagem 1 %32 Samsung HMX-W300 USB Port Replacement: passo 8, imagem 2 %32 Samsung HMX-W300 USB Port Replacement: passo 8, imagem 3 %32
    • After removing the battery housing, take the battery out.
  9. Samsung HMX-W300 USB Port Replacement, USB Port: passo 9, imagem 1 %32 Samsung HMX-W300 USB Port Replacement, USB Port: passo 9, imagem 2 %32 Samsung HMX-W300 USB Port Replacement, USB Port: passo 9, imagem 3 %32
    • Use an iFixit opening tool to pry up the plastic cover.
    • Use tweezers to remove the wire from the slots.
  10. Samsung HMX-W300 USB Port Replacement: passo 10, imagem 1 %32 Samsung HMX-W300 USB Port Replacement: passo 10, imagem 2 %32
    • Remove both screws from the USB port using a Phillips #00 screwdriver.
  11. Samsung HMX-W300 USB Port Replacement: passo 11, imagem 1 %32 Samsung HMX-W300 USB Port Replacement: passo 11, imagem 2 %32
    • Push the USB port inside the case to remove it from the device.
Conclusão
Robert
Membro desde: 01/21/15
966 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team 9-2, Blackwell Winter 2015 Membro de USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 546
