Ir para o conteúdo principal
Samsung HMX-W300 Battery Replacement
O que você precisa
  1. Samsung HMX-W300 Battery Replacement, Disassembling Samsung HMX-W300: passo 1, imagem 1 %32 Samsung HMX-W300 Battery Replacement, Disassembling Samsung HMX-W300: passo 1, imagem 2 %32 Samsung HMX-W300 Battery Replacement, Disassembling Samsung HMX-W300: passo 1, imagem 3 %32
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 Battery Replacement: passo 2, imagem 1 %32 Samsung HMX-W300 Battery Replacement: passo 2, imagem 2 %32
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 Battery Replacement: passo 3, imagem 1 %32 Samsung HMX-W300 Battery Replacement: passo 3, imagem 2 %32 Samsung HMX-W300 Battery Replacement: passo 3, imagem 3 %32
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 Battery Replacement: passo 4, imagem 1 %32 Samsung HMX-W300 Battery Replacement: passo 4, imagem 2 %32 Samsung HMX-W300 Battery Replacement: passo 4, imagem 3 %32
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 Battery Replacement: passo 5, imagem 1 %32 Samsung HMX-W300 Battery Replacement: passo 5, imagem 2 %32 Samsung HMX-W300 Battery Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 Battery Replacement, Battery: passo 6, imagem 1 %32 Samsung HMX-W300 Battery Replacement, Battery: passo 6, imagem 2 %32
    • Remove the four screws from the battery housing using a Phillips #00 screwdriver.
  7. Samsung HMX-W300 Battery Replacement: passo 7, imagem 1 %32
    • Use the iFixit opening tool to pry the battery housing open.
  8. Samsung HMX-W300 Battery Replacement: passo 8, imagem 1 %32 Samsung HMX-W300 Battery Replacement: passo 8, imagem 2 %32 Samsung HMX-W300 Battery Replacement: passo 8, imagem 3 %32
    • After removing the battery housing, take the battery out.
Conclusão
6 outras pessoas executaram este guia.
Robert
Membro desde: 01/21/15
966 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team 9-2, Blackwell Winter 2015 Membro de USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 Membros
Autoria de 16 guias
2Comentários do guia
What type of battery is this? What part number should we use to order a replacement?
VanDemark - Responder
The type of battery should be printed on the case of the battery. Most likely it’s some type of lithium battery. The part number for the battery should be on the case as well. If you can’t find either of these on the battery case you can take the battery to a place that sales batteries and the personnel there should be able to tell you the type and part number for your battery.
Jarretti Reaves -
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 23
Ao todo: 2,462
