Ir para o conteúdo principal
Samsung HMX-W200 Control Buttons Replacement
O que você precisa
  1. Samsung HMX-W200 Control Buttons Replacement, Outer Case: passo 1, imagem 1 %32
    • Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
  2. Samsung HMX-W200 Control Buttons Replacement: passo 2, imagem 1 %32 Samsung HMX-W200 Control Buttons Replacement: passo 2, imagem 2 %32 Samsung HMX-W200 Control Buttons Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to separate and remove the bottom red casing. Do this by, pushing the tool into the seam and prying up the red casing as you move along the edges.
    • Make sure to separate all the corners before removing the red casing.
  3. Samsung HMX-W200 Control Buttons Replacement: passo 3, imagem 1 %32 Samsung HMX-W200 Control Buttons Replacement: passo 3, imagem 2 %32
    • Using the plastic opening tool, separate and pull away the red casing on the right of the LCD screen.
  4. Samsung HMX-W200 Control Buttons Replacement: passo 4, imagem 1 %32 Samsung HMX-W200 Control Buttons Replacement: passo 4, imagem 2 %32
    • To access the HDMI slot, move slider towards the bottom of the casing on the other side of the camcorder. The lid casing will lift up upon doing so.
    • After accessing the HDMI slot you will find a 5.00mm screw. Using a Phillips #00 screwdriver, remove the screw.
  5. Samsung HMX-W200 Control Buttons Replacement: passo 5, imagem 1 %32 Samsung HMX-W200 Control Buttons Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tool, separate and pull away the red casing to the left of the LCD screen.
  6. Samsung HMX-W200 Control Buttons Replacement: passo 6, imagem 1 %32 Samsung HMX-W200 Control Buttons Replacement: passo 6, imagem 2 %32
    • Remove the six 5.00mm screws by using a Phillips #00 screwdriver.
  7. Samsung HMX-W200 Control Buttons Replacement: passo 7, imagem 1 %32 Samsung HMX-W200 Control Buttons Replacement: passo 7, imagem 2 %32 Samsung HMX-W200 Control Buttons Replacement: passo 7, imagem 3 %32
    • Lift the two plastic tabs on the left side of the LCD screen and the single one on the right side on the black casing to open the device.
  8. Samsung HMX-W200 Control Buttons Replacement: passo 8, imagem 1 %32
    • Separate the front and back casing.
  9. Samsung HMX-W200 Control Buttons Replacement, Motherboard: passo 9, imagem 1 %32
    • Once inside the device, find the half that contains the motherboard of the device.
  10. Samsung HMX-W200 Control Buttons Replacement: passo 10, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use precision tweezers to gently pull out the USB connection from the motherboard.
  11. Samsung HMX-W200 Control Buttons Replacement: passo 11, imagem 1 %32 Samsung HMX-W200 Control Buttons Replacement: passo 11, imagem 2 %32
    • Remove the audio connector from the motherboard (red and black cables).
    • Using the plastic opening tool, lift the connectors from all sides before pulling it with your fingers.
    • Do not pull off the connectors by the cables. This could damage the connection from the speaker to the motherboard.
  12. Samsung HMX-W200 Control Buttons Replacement: passo 12, imagem 1 %32 Samsung HMX-W200 Control Buttons Replacement: passo 12, imagem 2 %32
    • Use precision tweezers to remove the connector joining the LCD and the motherboard.
  13. Samsung HMX-W200 Control Buttons Replacement: passo 13, imagem 1 %32 Samsung HMX-W200 Control Buttons Replacement: passo 13, imagem 2 %32
    • Remove the six 2.00mm screws with Phillips #00 screwdriver.
  14. Samsung HMX-W200 Control Buttons Replacement: passo 14, imagem 1 %32 Samsung HMX-W200 Control Buttons Replacement: passo 14, imagem 2 %32 Samsung HMX-W200 Control Buttons Replacement: passo 14, imagem 3 %32
    • Lift motherboard from top left side and pull away gently.
  15. Samsung HMX-W200 Control Buttons Replacement, Control Buttons: passo 15, imagem 1 %32 Samsung HMX-W200 Control Buttons Replacement, Control Buttons: passo 15, imagem 2 %32
    • Locate the metal plate under the motherboard. This plate should be removed.
    • Use a Phillips head #00 screwdriver to remove eleven 5mm screws.
  16. Samsung HMX-W200 Control Buttons Replacement: passo 16, imagem 1 %32 Samsung HMX-W200 Control Buttons Replacement: passo 16, imagem 2 %32
    • Lift the metal plate by pushing it up from the top right edge of the plate.
  17. Samsung HMX-W200 Control Buttons Replacement: passo 17, imagem 1 %32 Samsung HMX-W200 Control Buttons Replacement: passo 17, imagem 2 %32
    • Use precision tweezers to lift the button to be replaced.
    • The buttons of the device are firmly attached to the metal plate, so it will require a significant amount of force to pull away.
Conclusão
Haya Barakat
Membro desde: 10/04/16
521 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 3-6, Sullivan Fall 2016 Membro de USF Tampa, Team 3-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G6
4 Membros
Autoria de 13 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 284
