Ir para o conteúdo principal
Samsung HMX-QF20 Internal Microphone Replacement
O que você precisa
  1. Samsung HMX-QF20 Internal Microphone Replacement, Lens: passo 1, imagem 1 %32
    • Remove the 4 mm screw on the underside of the camcorder near the tripod mount.
  2. Samsung HMX-QF20 Internal Microphone Replacement: passo 2, imagem 1 %32
    • Remove the 4 mm screw next to the buckle of the hand strap closest to the lens.
  3. Samsung HMX-QF20 Internal Microphone Replacement: passo 3, imagem 1 %32
    • Open the LCD screen. Remove the 4 mm screw on the inside panel, located at top left corner.
  4. Samsung HMX-QF20 Internal Microphone Replacement: passo 4, imagem 1 %32
    • Firmly grip and pull the front casing on the lens to remove it.
    • Be sure to remove the front casing at gently as possible to prevent damaging the attached ribbon cable. If not careful, the ribbon cables could be torn.
  5. Samsung HMX-QF20 Internal Microphone Replacement: passo 5, imagem 1 %32
    • Remove the three 5 mm screws surrounding the lens.
Conclusão
Ian Dorset
Membro desde: 03/11/15
225 Reputação
Autoria de 2 guias
Equipe
Marist, Team 1-5, Laflen Spring 2015 Membro de Marist, Team 1-5, Laflen Spring 2015
MARS-LAFLEN-S15S1G5
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 436
