Introdução
Use this guide to remove the outer casing of your device.
O que você precisa
Pull the release tab away from the battery.
Slide the battery towards the release tab and then pull the battery away from the camcorder.
Rotate the camcorder so that the strap side is facing you.
Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
Uma outra pessoa concluiu este guia.
