Ir para o conteúdo principal
Samsung HMX-F90 Strap Replacement
O que você precisa
  1. Samsung HMX-F90 Strap Replacement, Battery: passo 1, imagem 1 %32 Samsung HMX-F90 Strap Replacement, Battery: passo 1, imagem 2 %32 Samsung HMX-F90 Strap Replacement, Battery: passo 1, imagem 3 %32
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Strap Replacement, Strap Side Outer Casing: passo 2, imagem 1 %32 Samsung HMX-F90 Strap Replacement, Strap Side Outer Casing: passo 2, imagem 2 %32
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Strap Replacement: passo 3, imagem 1 %32 Samsung HMX-F90 Strap Replacement: passo 3, imagem 2 %32
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Strap Replacement: passo 4, imagem 1 %32 Samsung HMX-F90 Strap Replacement: passo 4, imagem 2 %32
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Strap Replacement: passo 5, imagem 1 %32 Samsung HMX-F90 Strap Replacement: passo 5, imagem 2 %32 Samsung HMX-F90 Strap Replacement: passo 5, imagem 3 %32
    • With both hands, pull the side strap apart from the rest of the camcorder.
  6. Samsung HMX-F90 Strap Replacement, Hand Strap: passo 6, imagem 1 %32 Samsung HMX-F90 Strap Replacement, Hand Strap: passo 6, imagem 2 %32 Samsung HMX-F90 Strap Replacement, Hand Strap: passo 6, imagem 3 %32
    • Unfasten the strap from the outside.
    • Pull apart the velcro on the faux leather strap sheath to reveal the separate end of the strap.
    • The loose end can be pulled off the velcro and fed through the loop on the casing to free one end of the strap.
  7. Samsung HMX-F90 Strap Replacement: passo 7, imagem 1 %32 Samsung HMX-F90 Strap Replacement: passo 7, imagem 2 %32 Samsung HMX-F90 Strap Replacement: passo 7, imagem 3 %32
    • On the inside of the opened case, locate the silver metal plate and remove the 3mm Phillips screw.
    • Feed the strap through the hole to remove completely so that it can be replaced or cleaned.
Conclusão
Amir Harb
Membro desde: 09/26/17
705 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S13-G1, Boczar Fall 2017 Membro de USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 292
