Ir para o conteúdo principal
Samsung HMX-F90 Lens Replacement
O que você precisa
  1. Samsung HMX-F90 Lens Replacement, Battery: passo 1, imagem 1 %32 Samsung HMX-F90 Lens Replacement, Battery: passo 1, imagem 2 %32 Samsung HMX-F90 Lens Replacement, Battery: passo 1, imagem 3 %32
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Lens Replacement, Strap Side Outer Casing: passo 2, imagem 1 %32 Samsung HMX-F90 Lens Replacement, Strap Side Outer Casing: passo 2, imagem 2 %32
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Lens Replacement: passo 3, imagem 1 %32 Samsung HMX-F90 Lens Replacement: passo 3, imagem 2 %32
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Lens Replacement: passo 4, imagem 1 %32 Samsung HMX-F90 Lens Replacement: passo 4, imagem 2 %32
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Lens Replacement: passo 5, imagem 1 %32 Samsung HMX-F90 Lens Replacement: passo 5, imagem 2 %32 Samsung HMX-F90 Lens Replacement: passo 5, imagem 3 %32
    • With both hands, pull the side strap apart from the rest of the camcorder.
  6. Samsung HMX-F90 Lens Replacement, Lens: passo 6, imagem 1 %32 Samsung HMX-F90 Lens Replacement, Lens: passo 6, imagem 2 %32
    • Rotate the camcorder so that back is facing you. Then flip open the LCD screen.
    • Locate and remove the 4.5mm Phillips #00 screws in the LCD screen base.
  7. Samsung HMX-F90 Lens Replacement: passo 7, imagem 1 %32 Samsung HMX-F90 Lens Replacement: passo 7, imagem 2 %32
    • Close the LCD screen. Then lift the silver base away from the camcorder.
  8. Samsung HMX-F90 Lens Replacement: passo 8, imagem 1 %32 Samsung HMX-F90 Lens Replacement: passo 8, imagem 2 %32
    • Locate and remove the two 3.5mm Phillips #00 screws from the side of the camcorder.
  9. Samsung HMX-F90 Lens Replacement: passo 9, imagem 1 %32 Samsung HMX-F90 Lens Replacement: passo 9, imagem 2 %32 Samsung HMX-F90 Lens Replacement: passo 9, imagem 3 %32
    • Gradually pry off the outer casing using a prying tool.
  10. Samsung HMX-F90 Lens Replacement: passo 10, imagem 1 %32 Samsung HMX-F90 Lens Replacement: passo 10, imagem 2 %32 Samsung HMX-F90 Lens Replacement: passo 10, imagem 3 %32
    • Locate and remove the three 4mm Phillips #00 screws around the lens.
    • Gently remove the lens.
Conclusão
3 outras pessoas executaram este guia.
Amir Harb
Membro desde: 09/26/17
705 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S13-G1, Boczar Fall 2017 Membro de USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 1,334
