Ir para o conteúdo principal
Samsung Gusto 2 Speaker Replacement
O que você precisa
  1. Samsung Gusto 2 Speaker Replacement, Speaker: passo 1, imagem 1 %32 Samsung Gusto 2 Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Flip open the phone as shown in picture 1.
    • Remove the two screws highlighted in picture 1.
  2. Samsung Gusto 2 Speaker Replacement: passo 2, imagem 1 %32
    • Take your spudger and forcefully insert it between the black and silver part of the phone.
    • Once the spudger is successfully wedged in between these two pieces, circle the frame of the phone.
  3. Samsung Gusto 2 Speaker Replacement: passo 3, imagem 1 %32 Samsung Gusto 2 Speaker Replacement: passo 3, imagem 2 %32
    • The phone should be exposed like picture 1 once the case was removed.
    • The highlighted sections correspond to the bullet colors. To replace either simply disconnect the wires attached, and lift the piece off.
    • Speaker Component
    • Vibration Component
Conclusão
Michael Huang
Membro desde: 03/30/15
403 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 2-5, Shastany Spring 2015 Membro de UMass Dartmouth, Team 2-5, Shastany Spring 2015
UMASSD-SHASTANY-S15S2G5
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 552
