Ir para o conteúdo principal
Samsung Gravity TXT microSD Card Replacement
O que você precisa
  1. Samsung Gravity TXT microSD Card  Replacement, Battery: passo 1, imagem 1 %32 Samsung Gravity TXT microSD Card  Replacement, Battery: passo 1, imagem 2 %32
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
  2. Samsung Gravity TXT microSD Card  Replacement: passo 2, imagem 1 %32
    • Lift the back cover away from the main body of the phone.
  3. Samsung Gravity TXT microSD Card  Replacement: passo 3, imagem 1 %32
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
  4. Samsung Gravity TXT microSD Card  Replacement, microSD Card: passo 4, imagem 1 %32 Samsung Gravity TXT microSD Card  Replacement, microSD Card: passo 4, imagem 2 %32 Samsung Gravity TXT microSD Card  Replacement, microSD Card: passo 4, imagem 3 %32
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
Conclusão
Mounir Karmada
Membro desde: 07/07/15
465 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team 1-1, Renguette SU 2015 Membro de IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 235
