Ir para o conteúdo principal
Samsung Gravity TXT SIM Card Replacement
O que você precisa
  1. Samsung Gravity TXT SIM Card Replacement, Battery: passo 1, imagem 1 %32 Samsung Gravity TXT SIM Card Replacement, Battery: passo 1, imagem 2 %32
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
  2. Samsung Gravity TXT SIM Card Replacement: passo 2, imagem 1 %32
    • Lift the back cover away from the main body of the phone.
  3. Samsung Gravity TXT SIM Card Replacement: passo 3, imagem 1 %32
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
  4. Samsung Gravity TXT SIM Card Replacement, SIM Card: passo 4, imagem 1 %32 Samsung Gravity TXT SIM Card Replacement, SIM Card: passo 4, imagem 2 %32 Samsung Gravity TXT SIM Card Replacement, SIM Card: passo 4, imagem 3 %32
    • Using your finger, push the SIM Card down and slide out of the slot.
    • Slide the SIM card out enough to grab it firmly.
    • Remove the SIM card away from the phone.
    • Follow the visual on the bottom of the SIM card slot to put the SIM card back in the correct orientation.
    • When sliding the SIM Card back in the slot, make sure the card goes all the way in the slot until it hits the stopper.
Conclusão
Mounir Karmada
Membro desde: 07/07/15
465 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team 1-1, Renguette SU 2015 Membro de IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 895
